Main > Project Announcements
Donkey Kong Mame Conversion
astroone:
I got a Gutted Donkey Kong Cabinet 2 year's ago that went through 2 conversion's Donkey Kong 3 then Playchoice and now Mamed
I didn't cut into the cabinet when I built my Cp just due to respect that it is a classic and now I am in the process of doing bondo work to it
If and when I do get another Cab I'll restore the cab as close to Original usally see cab's come and go on craigslist freebies
[/img]
astroone:
That cab look's to be in real good shape how's the left side I see maybe a little work that need's to be done on the front bottom
What kind of monitor is in the cab hope it's a Sanyo ezv
Rolpa:
I honestly don't know what exact model of monitor it is, but I'll check next time I wheel it out of the garage.
astroone:
Ok I got tired looking at a white Pc Monitor
I got some Plexi Glass and Cut it with a Dremel to fit in the Monitor area next I taped it around the monitor edge's then taped some paper in the middle spray painted the plexi.
Next I drilled some holes in the speaker cab with a couple of 1x1 in the speaker cab to hold the plexi on top then used a black sharpie on the edge of the monitor to get rid of the edge white here's the result.
The Marquee is lit by a 12v 12 Led that I got on ebay
My son is sure having a blast ;D
astroone:
Look what I Scored today on Craigslist ;D
