Main > Everything Else
SOLVED (in a way): Are these indications my hard drive is going to eat it?
newmanfamilyvlogs:
--- Quote from: Gray_Area on March 08, 2011, 03:09:05 pm ---
--- Quote from: ark_ader on March 07, 2011, 07:01:04 pm ---Stick it in the freezer in a baggie.
Hah
No. Seriously.
http://www.datarecoverypros.com/hard-drive-recovery-freeze.html
Howard_Casto:
--- Quote from: Gray_Area on March 05, 2011, 03:28:37 am ---I'm using XP 32bit. Most of the time, I prefer to use thumbnails in directory viewing. When I open a directory that has a lot of items in it, it can take up to thirty seconds for it to 'catch up' so that I can scroll through the whole thing. Disabling 'cache thumbnails' helps this a bit.
However. In the last day or so, opening a folder here and there has crashed that whole part of Explorer. That is, all system/data folders I have open at the time, and the task bar disappears for a little while.
Are these signs of mortality?
Corrupted thumbnails or thumbnails with a jpeg exploit in them can crash explorer in xp. Of course corrupted thumbnails can often occur from a thrashed hdd, so that doesn't really help you identify the problem.
If the computer is important, buy a new hdd immediately, install a FRESH copy of xp on it, install AVG anti-virus and start transferring your junk over. Worst case scenario you've now got a spare hdd that you can use as a portable drive.
Gray_Area:
I was also having trouble with Ultramap (I couldn't edit or create maps), nor access msconfig. I was using TinyXP 11. I guess it wasn't that stable. It's not in the usual place anymore.
So, I re-installed XP Pro. I used the same TXP disc, but went for a full install. Bliss. Very snappy....though I have switched to icon view in folders to keep things that way.
I stopped using AVG a few months ago. Every time a scheduled scan time came up, the time in the box would jump an hour ahead. Basically, it wouldn't automatically scan. Since then I've been using MS Security Essentials. I like it.
Navigation
[0] Message Index
[*] Previous page
Go to full version
