Main > Project Announcements
My first cab: Mame Bartop cab from laptop guts.
ulfur:
--- Quote from: phatmeat on March 05, 2011, 03:44:56 pm ---I just did something like what you are doing . Have fun . Here is a link , I dont have pics of the built though ???
http://forum.arcadecontrols.com/index.php?topic=109825.0
Here is the best pic of the on switch that I wired to a arcade button to turn the computer on and put into sleep mode . Since the switch is most likely a surface mount you will have to do a continuity test the switch leads . The solder area is really small . I was able to connnect 2 wires to the solder joints. It was 24 or smaller gauge wire.
Hope it helps GL
Thanks for the advice. My board has the exact same switch on it. The solder area is quite small and it indeed is a smc.
I was thinking I'd just bring it to a friend that has considerably more soldering experience than me and also has access to better equipment. He hand solders surface mounts for a living ;)
