Main > Everything Else
Whack - A - Mole Virus
Dartful Dodger:
--- Quote from: hypernova on February 28, 2011, 05:27:47 pm ---It said "start-ups" which I took as meaning plugging in the machine/turning it on. 511 games in a highly trafficked arcade wouldn't last very long.
Either way it would have been easy for the arcade owners to know there was something fishy going on. If after 511 times all the wack-a-moles bought on the same day would have failed. If it was the amount of games played, they'd all fail within a month of each other.
All the games would be failing a year and a half after they were bought so even the company he worked for would figure it out.
I second SavannahLion idea. He should have waited until the counter hit 500 and then have the games fail at a randomized rate. This way they won’t fail to soon. Some would fail close to 500 days others would fail years later.
Doubling his rate after a year was also a little obvious. Using the randomizing, he could have gone up slowly so it wouldn’t be as obvious. Whoever was luckily enough to have a machine that didn't fail right away, would end up being unlucky by paying higher fees.
ChadTower:
--- Quote from: Dartful Dodger on February 28, 2011, 05:57:22 pm ---Either way it would have been easy for the arcade owners to know there was something fishy going on. If after 511 times all the wack-a-moles bought on the same day would have failed. If it was the amount of games played, they'd all fail within a month of each
You're giving way too much credit to the repair staff. Repair strategy may as well be wack-a-mole itself. They wouldn't notice that type of pattern.
ark_ader:
Sounds like Windows ME or Vista 64.
Dartful Dodger:
--- Quote from: ChadTower on March 01, 2011, 10:30:12 am ---You're giving way too much credit to the repair staff. Repair strategy may as well be wack-a-mole itself. They wouldn't notice that type of pattern.
Someone noticed.
ChadTower:
The originating article says that the manufacturer is the one that noticed.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
