Main > Project Announcements
Nanocade ArcadeStik - Now with pictures of the construction (01.03.11)
emphatic:
Sweet case! :applaud:
opt2not:
Beauty! Nicely done.
crashwg:
How is the joystick mounted?
robertsig:
Can you show the side with the cable (USB I presume?) coming out for attachment to a PC? Will the kit be sold with a hole for that purpose, perhaps for a rubber grommet or something similar?
Savannan:
very nice controller!!!
but I see 1 problem. those screws. if you loose a rubber foot that screw might scratch a surface. See if you can get a rubber foot that would allow a screw thru the middle of it and secure both the foot and the bottom plate. I just know from experience that the self adhesive feet come off after awhile.
other than that little problem...great job!!!!
