Main > Project Announcements
ghetto cab - completed
ghettodish:
Finished the monitor box. I have used this design a few times now for the monitor and it works out great for adding structural integrity to the whole cab. I mount the monitor to the backing, set the bezel in place, then measure the space in between the two. That's how to get the dimensions for the 4 frame pieces.
borals:
Where did you get that LCD monitor bezel?
ghettodish:
--- Quote from: borals on February 27, 2011, 06:14:12 pm ---Where did you get that LCD monitor bezel?
It's the 20" one from Happ. Can you see in the above picture where I had to cut the bezel off of the monitor? That made the Happ bezel fit perfect without removing the whole case from the monitor.
ghettodish:
My hidden admin buttons. This box gets mounted behind the top coin door. The light switch is Main Power, toggle is for Coin/Free Play, and the buttons are Tab and Enter. The guts are still in the speaker housing for power/volume. The grill still fits. The buttons are mounted to a scrap of Lexan with paper under it. The speaker housing is mounted to the "box"
ghettodish:
got a couple coats of Kelly-Moore "carbon" on it today. UPS just dropped of the t-molding. I'm just waiting for the artwork....
