Author Topic: Where can I find a Front Line twist-fire control?  (Read 6403 times)
VanillaGorilla
  • Coin detected in pocket
« on: February 21, 2011, 04:25:59 pm »
I know this is probably a fruitless attempt, but is it possible to find one of these anywhere anymore? I'd love to have one for a multi-Taito I'm planning...
If anyone has any alternate suggestions, I'm all ears. I've been dying to play a game of Front Line for , oh about 30 years now :)
ahofle
    • Arcade Ambience Project
Re: Where can I find a Front Line twist-fire control?
« Reply #1 on: February 21, 2011, 05:06:18 pm »
Ultimarc has a rotary board:
http://www.ultimarc.com/rotary.html
which converts this Happ rotary stick to USB:
http://www.happcontrols.com/joysticks/50561800.htm
VanillaGorilla
« Reply #2 on: February 21, 2011, 05:11:58 pm »
I didnt think the Happ would work quite the same, how would you fire? Am I missing something?
mgb
  • Last login:February 21, 2024, 06:18:13 pm
  • North East, US
Bender
« Reply #4 on: February 21, 2011, 08:13:59 pm »
could you use a push pull spinner?
mgb
  • North East, US
« Reply #5 on: February 21, 2011, 08:20:20 pm »
I would think in mame that using a push pull spinner would be the easiest way, right?
ahofle
« Reply #6 on: February 21, 2011, 08:35:18 pm »
Sorry I was thinking of a different game.  Yeah definitely push/pull spinner would be your best bet.
Here's one from groovy game gear:
http://groovygamegear.com/webstore/index.php?main_page=product_info&products_id=311
Xiaou2
  • NOM NOM NOM
« Reply #7 on: February 21, 2011, 10:03:59 pm »
FrontLine is a special type of controller..   Its not really a spinner.
 Its closer to a rotary stick, however, only has like 4 directions.
Each turn of the dial activates one of the switches, as the dial spring-snaps into place.
 In addition, theres a 'push to fire' vertical switch as well.
 A spinner would be problematic, as it does not lock into place at the appropriate angles...
Not even sure if the game supports that anyways.
 A combination of a standard rotary stick (for turning) and a trigger stick with 2 buttons would probably be a decent compromise.
 The biggest problem would possible be the way things are wired.
 Sadly, currently, mame has no true Rotary Stick support.
In order to use a rotary stick, you need to buy a special hacky controller board which converts the inputs from 12 switches, to 2.  This is not accurate.  May not be accurate at game start (character facing a different direction that the switch being activated), and may easily become de-calibrated in game if you turn the dial too fast.  (which is exactly why they didnt make it a 2 switch system)
mgb
  • North East, US
« Reply #8 on: February 21, 2011, 10:34:00 pm »
The frontline controller is an 8 way rotary. but the problem still may be in the way that mame handles it all.
If you were to use an frontline rotary/fire controller, I guess you would need a rotary interface board too
isucamper
    • my project arcade blog
THE SYSTEM          Popeye
huygens
  • Last login:October 31, 2011, 01:33:08 am
« Reply #10 on: February 21, 2011, 11:28:56 pm »
The Taito Frontline Controller is wired like a regular 8-way joystick + a button. A rotary Interface isn't required.
RandyT
  • Last login:May 06, 2024, 12:12:44 pm
    • GroovyGameGear.com
« Reply #11 on: February 21, 2011, 11:37:25 pm »
The GP-Wiz40's built-in Roto-X feature supports a special mode for games controlled in the way Front-Line was.  But you still need a rotary switch based control to use it.
VanillaGorilla
« Reply #12 on: February 21, 2011, 11:46:03 pm »
Here's one.
http://www.videogameparts.com/product.sc?productId=838&categoryId=48
Nope, the page says out of stock... I'm thinking I might just be better off looking for an entire front line to restore..
« Last Edit: February 21, 2011, 11:49:39 pm by VanillaGorilla »
mgb
  • North East, US
« Reply #13 on: February 22, 2011, 12:34:29 am »
Sorry about that, I didn't notice the out of stock
Xiaou2
  • NOM NOM NOM
« Reply #14 on: February 22, 2011, 02:18:56 am »
 Yes, but we were talking about using a mechanical rotary as an alternative control method. Afaik, Mech.Rotaries are far more plentiful and easier to get hold of.
 Correct me if Im wrong, but isnt there a keypress buffer delay?  Meaning, if you turn 8 clicks in less 1/4 a second, it might take like 1 full second for the onscreen character to fully rotate to the intended position due to mames need for consecutive keypresses rather than the direct switch?
isucamper
« Reply #15 on: February 22, 2011, 09:42:50 am »
Randy!  Sorry to be a pill but have you done anything to fix the bug in Frontline mode?  Just to refresh your memory, the GPWiz should send an always on signal instead of a pulse when in this mode.  Otherwise, between each round or after each death your aim resets to a default and jumps when you turn the rotary.
Also, just a plug for this device: besides this small issue (and another small bug in certain versions of MAME that won't let you use the player 1 rotary inputs) it works great!  Played a ton of Frontline, Wild Western, Tin Star, and Sherrif with it, and I got to like those games so much I bought a Wild Western.
THE SYSTEM          Popeye
isucamper
« Reply #16 on: February 22, 2011, 09:44:44 am »
No, MAME interprets the inputs as an 8 way stick, so it can jump to whatever direction is input.
THE SYSTEM          Popeye
