Main > Project Announcements
Dynamo conversion (most likely very blue)
Pages: << < (3/3)
RandomCitizenX:
 I finally got all of the buttons out of the CP. It only took a set of channel locks and some language that would most likely be  :censored:. As far as the joysticks not lining up, I guess my picture just doesn't have the right angle to show it properly. After examining it several times it seems that the first player stick is using an original hole while second player stick had a new one cut for it. The new hole was cut at a slight diagonal to the original which makes the two not line up at all.  :dunno
I never thought of using bondo to plug the holes, but that stuff sure seems to be the goto product when it comes to fixes in this hobby.
Donkbaca:
Oh I gotcha.
look at the CP bottom, you can see that origianlly ther was only one start button, and you can see the outline of 2 more joystick mounts where the buttons were.  It must have been a 1p smash tv or other dual joystick game.
I see what you mean, what a sloppy job.
What kind of button layout are you looking to do?
RandomCitizenX:
I am going to use the street fighter layout (I may shift the lower row to the left slightly) with a spinner in the middle since my utrak doesn't seem like it will fit.
SithMaster:
Perhaps modifying the panel to function similar to a galaxian panel.  I'm pretty sure that it was two pieces of metal with the piece all the controls attached to being bolted to the main cp in addition to wood underneath.
The main problem I see with that idea though is the edge towards the player won't be clean.
Pages: << < (3/3)
Go to full version
