Main > Main Forum
Marquee light is way too bright. Can I wire in a resistor to dim it?
Pages: << < (3/3)
llars:
How about something like a dimmer?
http://www.amazon.com/gp/product/B0000BYEF6/ref=pd_lpo_k2_dp_sr_1?pf_rd_p=486539851&pf_rd_s=lpo-top-stripe-1&pf_rd_t=201&pf_rd_i=B000BQYKIQ&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=14XEMSM8YQTPV7DTVTDY
mgb:
Yes you can.
They can get a little expensive though.
One guy I know bought special dimmers for his under cabinet led lighting and paid $80 per dimmer.
Here are some
http://www.superbrightleds.com/cgi-bin/store/index.cgi?action=DispPage&Page2Disp=%2Fhobby.htm&gclid=CPju5LS2s6cCFYHc4AodAjnhAg
BobA:
You can use a fan speed control for a PC on the LED to dim it.   These only cost 4 or 5 dollars.
Dervacumen:
--- Quote from: justinjstark on February 14, 2011, 10:54:34 am ---
--- Quote from: mgb on February 14, 2011, 08:45:56 am ---What about the possibility [sic] of putting another layer of something like a wax paper behind your marquee in order to better diffuse the light.
--- Quote from: mgb on February 14, 2011, 08:45:56 am ---I'm not sure this will do much, but what about the possibilty of putting another layer of something like a wax paper behind your marquee in order to better diffuse the light.
This could work.
One thing that bothers me is that, while the marquee colors match beautifully when the marquee light is off, the marquee colors get a bit orange and don't match the cab so well when the light is on.  Maybe I could find a brown, semi-transparent material to put behind the marquee graphics.  Any ideas what I could use?  I will try to find a hobby store around here this afternoon.
Many years ago I used something called onion skin paper for tracing images but it was 8 1/2" x 11" so it may be problematic.  The paper was semi-translucent and brown.  I'm not sure what the real name is but it was commonly used in drafting and circuit tracing about, oh, say, 35 years ago.  It's probably still around if you check at an art supply store.  I imagine this would be a great application however you would have to be very mindful of applying it or any other material in equal layers to maintain a uniform translucency.
justinjstark:
--- Quote from: BobA on March 03, 2011, 06:45:54 pm ---You can use a fan speed control for a PC on the LED to dim it.   These only cost 4 or 5 dollars.
Thank you.  This may be a good solution for me.
Pages: << < (3/3)
Go to full version
