Main > Everything Else
Projector Location
<< < (4/4)
eds1275:
What I have done in the past is attach a piece of MDF to the projector's mounting holes. Add a speaker pole mount on the MDF, and then stick the whole shebang on a tripod speaker stand. Looks clean, can be moved/taken down, and is sturdy enough to leave up.
Stand
http://accessories.musiciansfriend.com/product/Musician%27s-Gear-Standard-Speaker-Stand-?sku=451036
Mount
http://www.samedaymusic.com/product--ULTBMB200K
Alternative wall mount
http://accessories.musiciansfriend.com/product/On-Stage-Stands-Speaker-Wall-Mount-Bracket-Pair?sku=421709
javeryh:
What is the shortest throw for a projector to go about 100"?  My TV room is only 7'10" wide but I'd love to get a huge screen on the wall!
Dexter:
It depends on the projectors throw ratio really.
Give this a whirl.....
http://www.projectorcentral.com/projection-calculator-pro.cfm
ark_ader:
Thanks for that mate, I can fiddle with settings to see if I can get the distance right.
I only have 7' to play with in the lab, but nearly mini cinema size in the downstairs lounge about 120" on the blinds.
Only the problem is the reverse image showing outside in the garden, so no 18+ films.
Sweet!  :applaud:
Dexter:
Grab a white roller blind with blackout lining. Cheap as chips and works a treat at both masking incoming light and stopping your neighbours seeing the projected image.. I used one for about 6 years for my projector.
Navigation
[0] Message Index
[*] Previous page
Go to full version
