Main > Everything Else
Projector Location
<< < (3/4) > >>
AtomSmasher:
--- Quote from: boykster on February 20, 2011, 01:46:01 pm ---Howard C hit the highlights - a properly done ceiling mount will be bulletproof.  No fiddling or adjusting.  You set it up once, and you're done.  Shelf mounts (or super cheap ceiling mounts) will be a constant headache of messing.
If you do go shelf mount, at least consider rigging it up so that it rigidly mounts the projector.  buy a cheap ceiling mount (or kit) and use the mounting plate / spider in some way that attaches the projector to the shelf.  That way you don't have to worry about it getting bumped or something.
I agree with the statement of attaching the projector to the shelf somehow.
When I did my shelf mount, I had to have the projector at an angle pointing down because of the height of the projector and how close the screen was.  In order to make it a solid mount, I bought a cheap wire stand thing.  I think it's supposed to be used as a way to separate a kitchen shelf into two small shelves.  I cut the ends off one side, and attached the rear legs to the wood shelf I was mounting the projector on.  I then attached the projector using screws and large washers (since the shelf was made of wire, it was easy to do).  It worked great and cost me less then $5 to do.
When I did my ceiling mount, I bought a ball joint, cut out some pieces of metal (I think they were originally made to mount adjustable shelving) and made the whole thing for less then $10.
Basically I would see the problem I had, then would wander around Home Depot until I found pieces I could use to solve the problem without spending $50-$100 on expensive mounts.
boykster:
I wander around ebay looking for expensive stuff for cheap  ;D
Howard_Casto:
--- Quote from: boykster on February 23, 2011, 01:31:30 pm ---I wander around ebay looking for expensive stuff for cheap  ;D
I choose to wander the earth, hoping to find the enlightenment I seek.  ;)
Ed_McCarron:
--- Quote from: Howard_Casto on February 20, 2011, 08:10:47 am ---where the thing can't physically be touched or effected by foot stomps and therefore never needs adjusting.
Except for the fact that every time someone walks by upstairs it looks like a 6.8 on the Richter scale hits your movie.
ark_ader:
--- Quote from: Ed_McCarron on March 01, 2011, 06:31:57 pm ---
Not good, especially if you are watching Lord of the Rings.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
