Author Topic: Probably good monitor for a sub-miniature cab  (Read 1960 times)
crashwg
« on: February 09, 2011, 03:00:59 pm »
http://www.dealextreme.com/p/pl8006-portable-8-color-lcd-monitor-tv-w-ypbpr-vga-input-47-870mhz-55245
8" diagonal, 800x600, 4:3 aspect ratio and VGA input.
$72 might be a little high...
By the thorax and abdomen
Lemme say it again
In my land of pretend
I use bees as a mf'n pen
  • Last login:May 06, 2024, 04:31:28 pm
Re: Probably good monitor for a sub-miniature cab
« Reply #1 on: February 09, 2011, 04:45:14 pm »
Too bad the screen isn't centered in the bezel.  I wondr how easy it would be to open it up?   >:D
NIVO
  • Last login:August 08, 2022, 12:32:13 pm
« Reply #2 on: February 09, 2011, 10:54:22 pm »
could be useful as a 3rd display for the dot matrix portion of a pinball cab
Gray_Area
  • -Banned-
  • -Banned-
« Reply #3 on: February 11, 2011, 01:41:27 am »
47mhz to 870mhz??
-Banned-
MonMotha
« Reply #4 on: February 11, 2011, 01:55:37 am »
47mhz to 870mhz??
The (probably obsolete, given that it is analog only) TV tuner input.  That's the bottom end of VHF up to about as high as UHF broadcast and cable ever went.
« Reply #5 on: February 11, 2011, 02:42:33 am »
Sark
  • Last login:December 06, 2017, 08:10:32 pm
« Reply #6 on: February 11, 2011, 09:56:10 am »
Both look really interesting, note that the first one can be battery powered.  Thanks for the idea.
Bender
« Reply #7 on: February 11, 2011, 10:27:00 am »
How about this one instead?
http://www.dealextreme.com/p/8-tft-lcd-monitor-with-remote-controller-and-stand-640-480-32019
...a bit pricier though.
I have a couple of these, I got them from ebay a little cheeper, and the image quality is pretty good, sound not so good
Easy to decase, perfect for a tiny bartop cab
« Last Edit: February 11, 2011, 10:28:59 am by Bender »
ark_ader
  • I glow in the dark.
« Reply #8 on: February 12, 2011, 07:06:47 am »
Find yourself an original PS1 screen.  These can output  display VGA with a mod.
Edit: Fixt!
« Last Edit: February 12, 2011, 03:43:08 pm by ark_ader »
crashwg
« Reply #9 on: February 12, 2011, 11:45:09 am »
Find yourself an original PS1 screen.  These can output VGA.
Wait, why would you want to output VGA from a PS1 screen?
Lemme say it again
Bender
« Reply #10 on: February 12, 2011, 02:45:05 pm »
I think he means it will display VGA
