Main > Everything Else
Just installed XBMC on my iPad
<< < (10/15) > >>
Donkbaca:
I don't think apple authorizes international sims
SavannahLion:
I never thought it could happen but I've to re-rank my opinion of xiaou to make room for someone else.
shmokes:
--- Quote from: ark_ader on February 15, 2011, 10:54:14 am ---
So I will defer to a higher power.  I am sure they will concur with your opinions.
Not exactly the most objective source on the matter . . .
Whether in the U.S. or U.K. locking and unlocking work the same.  A locked phone won't work with unauthorized sims.  The fact that providers in your country have authorized certain international sims is irrelevant.  In any case, U.S. carriers do not allow you to use "international sims" in their phones.  You either use your regular sim or you unlock your phone.  I strongly recommend the latter.
javeryh:
Does this allow streaming over 3G or Wifi (outside of the network you are hooked up to)?  I just want to be able to stream my entire iTunes library to my iPhone wherever I am.  Is there anything out there that will work (for free)?
shmokes:
--- Quote from: javeryh on February 15, 2011, 05:23:03 pm ---Does this allow streaming over 3G or Wifi (outside of the network you are hooked up to)?  I just want to be able to stream my entire iTunes library to my iPhone wherever I am.  Is there anything out there that will work (for free)?
My first instinct is no.  If you could set up some persistent VPN on your device, and if XBMC would browse through that . . . maybe.  When I go into add sources and browse the options I have are:
SAP Streams
UPnP Devices
Windows Network (SMB)
Zeroconf Browser
I don't know what SAP Streams or Zeroconf Browser are, so maybe you could look into those.  UPnP won't do you any good.  Windows Network might work over VPN, but I sort of doubt XBMC is set up to work over VPN on an iOS device.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
