Main > Project Announcements
First cab:CHERRYCADE -Finished!
Pages: << < (7/9) > >>
SirStupidQuestion:
Love your work. Did you make the Cab wider cause you went with 6 buttons instead of the standard 4 on weecade? how wide is your cab total?
dandare:
Thank you!
No the dimensions are the same as the four button layout, just crammed in a bit more.
Termin8tor:
Don't know if you've decided what to use for a marquee retainer but I used FFA Concept PVC Corner Black from B&Q under £5 for 2 metres
dandare:
Mate, that's brilliant!
I was going to use some aluminium angle i had, but that covered up half the sign!
B&Q here i come!
Cheers pal!
Termin8tor:
update  ???
Go to full version
