Main > Project Announcements
First Arcade Project - Ideas and progress
fauxc:
--- Quote from: fantoboy on February 01, 2011, 03:04:47 am ---Good luck with the rotating CP. That looks like a real pain. Any idea on what the name, art-style, or color scheme will be?
Not yet, I'm still thinking about that.
fauxc:
--- Quote from: mgb on February 01, 2011, 09:43:04 am ---Laminating is definately a great finish. I kept away from it and then just finally laminated a cabinet. I love it.
If you laminate, are there any issues with the T-moulding not covering the edges of the laminate? Also, what type of wood did you use for the laminated cab?
Thanks.
mgb:
--- Quote from: fauxc on February 01, 2011, 12:58:33 pm ---If you laminate, are there any issues with the T-moulding not covering the edges of the laminate? Also, what type of wood did you use for the laminated cab?
There doesn't have to be . You can either use a thinner wood so that then with the laminate, it still equals 3/4" so that you can stick with the standard 3/4" t-molding or you can do like what I did and just use thicker t-molding. I'm using 13/16" t-molding to cover the laminate edge.
Epyx:
--- Quote ---If you laminate, are there any issues with the T-moulding not covering the edges of the laminate? Also, what type of wood did you use for the laminated cab?
If you look at my lamination tutorial or aliens cab build in signature you can see an how the two look together close-up. I personally use MDF for my cabinet builds (sides and CP) but use plywood for the interior stuff.
When laminating with T molding just make sure your measurements add up...for example a tried and tested method is to use 5/8" MDF for your sides and laminate with 1/16" Laminate...this works out to exactly 3/4" and will ensure that 3/4" T Molding lines up perfectly.
Quick example from my thread:
Good luck! :)
fauxc:
--- Quote from: Epyx on February 01, 2011, 02:36:47 pm ---
--- Quote ---If you look at my lamination tutorial or aliens cab build in signature you can see an how the two look together close-up. I personally use MDF for my cabinet builds (sides and CP) but use plywood for the interior stuff.
This is a nice cab that you built. Very Professional looking. Thanks for the tips!
--- Quote from: Rando on February 01, 2011, 09:04:45 am ---You didn't list PC specs, do you have something onhand that you plan on using yet?
I'm probalby going to use an older laptop that I have with a cracked monitor screen and I think that it should be powerful enough. It's currently running XP and I think that it's a P4.
