Main > Project Announcements
BritInVA's Project Arcade II attempt :)
Pages: << < (14/20) > >>
drventure:
People have often built an "admin" panel right below the monitor with coin/start etc buttons on it.
It'd be better below than above.
mgb:
They'd typically be under the monitor. It looks like you have room below the shelf that the Tv is on.
britinva:
--- Quote from: mgb on February 14, 2011, 07:02:30 pm ---They'd typically be under the monitor. It looks like you have room below the shelf that the Tv is on.
I think that area is talen up by the Control pane box - think your both right - under TV is best..... just got to work it out. Wish I had not glued everything now.
britinva:
OK, so made modifications to have some cross-console buttons under the screen.
Ordered a 1-1/8-Inch Forstner Bit today too - hopefully that will arrive before weekend.
drventure:
Why not build a short little riser box right below the TV opening, it'll cover a small bit of the CP but it looks like there's space.
Go to full version
