Author Topic: What happened to hyperspin?  (Read 1854 times)
hfdpro
  • Last login:April 23, 2011, 10:16:27 am
« on: January 27, 2011, 12:23:48 pm »
Having problems getting on the hyperspin site.  Keep getting a "server not found".
I have deleted all the cookies, cache,and history.  Tried on multiple computers.  Still
getting that error.  Anyone know what's going on?
Thanks,
Russ
Hoopz
  • Last login:February 09, 2024, 02:36:26 pm
  • Intellivision Rocks!
Re: What happened to hyperspin?
« Reply #1 on: January 27, 2011, 12:27:20 pm »
What link are you using?  This works for me:
http://www.hyperspin-fe.com/
I think they went to a new website awhile ago? Not 100% sure though.
hfdpro
« Reply #2 on: January 27, 2011, 12:31:34 pm »
I'm using the same one.  Still does not work.
Weird.  Anyone else having any problems?
Also, if anyone can give me the contact info for an administrator from HS I would appreciate it.
Russ
« Last Edit: January 27, 2011, 12:33:08 pm by hfdpro »
FrizzleFried
  • Last login:May 30, 2023, 01:14:24 pm
    • Idaho Garagecade
« Reply #3 on: January 27, 2011, 12:32:47 pm »
Workin' for me...
Try a different DNS server...
hfdpro
« Reply #4 on: January 27, 2011, 12:33:35 pm »
Sorry, how is that done?
trevski
  • Last login:May 14, 2011, 03:27:44 pm
« Reply #5 on: January 27, 2011, 02:16:38 pm »
Still having problems? Lets check how your DNS is resolving the address - I'm going to assume you're using Windows in some form.
1. Open a dos/command box
2. Type nslookup www.hyperspin-fe.com
press Enter
3. You should get a short report that looks like this:
Code: [Select]
Server:  myrouter.home
Address:  192.168.0.1
Non-authoritative answer:
Address:  69.10.48.154
Aliases:  [url=http://www.hyperspin-fe.com]www.hyperspin-fe.com[/url]
Try that and let us know what you get.
hfdpro
« Reply #6 on: January 27, 2011, 06:12:18 pm »
Trevski,
Thanks for helping me out here.
I did like you said and this is what I got back:
Server: mater.myactv.net
address: some numbers
mater.myactv.net can't find www.hyperspin-fe.com: server failed
hfdpro
« Reply #7 on: January 27, 2011, 06:13:59 pm »
I just did the same thing with ebay and got back a confirmation with a name, addresses, and aliases.
Russ
hfdpro
« Reply #8 on: January 27, 2011, 06:27:28 pm »
Trevski,
You got me on the right track.  I changed my dns to 8.8.8.8 ; a gaming dns.
This brought the page back.
Is there an explanation to why or how this problem may have started?
Thanks,
Russ
EwJ
  • Last login:October 12, 2022, 10:16:06 pm
« Reply #9 on: January 27, 2011, 07:25:54 pm »
Check out OpenDNS http://www.opendns.com/   - see bottom right of page for numbers.
More info here -->  http://www.opendns.com/support/article/4     flushdns, etc.
« Last Edit: January 27, 2011, 07:27:44 pm by EwJ »
Hoopz
« Reply #10 on: January 27, 2011, 08:54:50 pm »
Trevski,
Thanks,
Russ
Be aware that changing your DNS to Google's DNS server, which you have done, may cause slowdowns with torrent programs and other items.  I read a story about it a few weeks ago.  In the grand scheme of things it may not be a big deal but I just wanted to throw it out there.
Glad you got the site working for you though.   :cheers:
