Main > Project Announcements
Beer Pong Table Project
upprc04:
Where on the table would that be and would the water stay clean? From my experience of playing, some beer usually ends up getting on the table and could get moved around/in to it. Cool Idea and I would love to see it work.
roberts123:
I plan on building on a little lip to protect that from happening. This is what I plan on using as the ball washer. It is a pretty famous toy that runs on back pressure to shot the ball up. There will be a little stopper to stop the ball from shooting the ball up into the air. I also plan to drill a drain hole in the bottom pipe so it will be easy to drain. I also believe I will make it work with the press of a button. I was thinking of taking an arcade button and instead of the button top place a beer cap on it. The only reason I will make this work by the press of a button is because the table will be used as more then just a beer pong table.
Rando:
--- Quote from: roberts123 on January 26, 2011, 10:45:50 am ---I plan on building on a little lip to protect that from happening. This is what I plan on using as the ball washer. It is a pretty famous toy that runs on back pressure to shot the ball up. There will be a little stopper to stop the ball from shooting the ball up into the air. I also plan to drill a drain hole in the bottom pipe so it will be easy to drain. I also believe I will make it work with the press of a button. I was thinking of taking an arcade button and instead of the button top place a beer cap on it. The only reason I will make this work by the press of a button is because the table will be used as more then just a beer pong table.
College kids would die if they came into a party and the pong table was setup with THAT as the automatic ball washer. Odd? Absolutely. But awesome? Quite.
Can't wait to see what the hell the finished product looks like! :applaud:
Donkbaca:
Beer pong is a game where you play ping pong with glasses of beer on the table. Beirut is the game where people throw ping pong balls at each other's glasses.
here is a link to a coo Beirut table:
http://www.google.com/search?q=texas+a%26m+beer+pong+table&hl=en&prmd=ivns&source=univ&tbs=vid:1&tbo=u&ei=8U1ATc7RKIjSsAP3rYG4CA&sa=X&oi=video_result_group&ct=title&resnum=5&sqi=2&ved=0CFwQqwQwBA
upprc04:
This looks like a nice washer:
