Author Topic: CP no longer working...  (Read 1021 times)
MagicManPA
  • Last login:January 12, 2019, 04:35:43 pm
« on: January 24, 2011, 11:16:11 pm »
Recently got this MAME cab up & running. I fire it up tonight & the cp buttons & joysticks do not work.
I'm running Mala & Paradise Arcade Shop's USB controller. Kept getting Microsoft error messages for the controller has malfunctioned. I tried plugging into other slots on the USB card then directly into the PC then into the hub on the front. Won't work anywhere. Then I tried using another cable to run from the controller to the USB port. Still won't work.
I go into the controller tab in Mala & try to run the "check". Nothing is registering. Look further and the label it had when it worked is no longer there or available.
The only thing I can assume is the controller itself took a crap & I will need to ask PAS to RMA it.
Has anyone else had a problem like this?
Finally got this thing going & now I can't even use it.  :angry: :angry: :angry: :angry:
mgb
  • Last login:February 21, 2024, 06:18:13 pm
  • North East, US
Re: CP no longer working...
« Reply #1 on: January 24, 2011, 11:36:20 pm »
Has it ever worked or was it new?
It may be a bad controller, contact the seller.
MagicManPA
« Reply #2 on: January 24, 2011, 11:46:41 pm »
It was working fine until I turned it on tonight. I didn't change anything since last use.
mgb
  • North East, US
« Reply #3 on: January 24, 2011, 11:53:51 pm »
was there any driver that you had to download?
MagicManPA
« Reply #4 on: January 25, 2011, 12:13:15 am »
Nope.
MagicManPA
« Reply #5 on: January 25, 2011, 12:18:09 am »
PAS already replied & is shipping me a replacement.  :applaud: :notworthy:
mgb
  • North East, US
« Reply #6 on: January 25, 2011, 12:20:57 am »
good to hear.
I hope it all works out
MagicManPA
« Reply #7 on: January 25, 2011, 12:22:21 am »
good to hear.
Thanks, I'll be bumping this thread if this doesn't solve it.  :lol
