Author Topic: My 1st cabinet build... (Picture heavy) *UPDATE 1/24*  (Read 3490 times)
MagicManPA
  • Last login:January 12, 2019, 04:35:43 pm
« on: January 18, 2011, 10:10:35 am »
This is my 1st cabinet build. I plan to do a trackball & wheel w/pedals cabinet in the future.  ;)
As you can see, it is not finished. The marquee is currently being made & I need to take more measurements for the CP overlay. I am also replacing the black t-molding with red. The side art will be hand painted by my girlfriend.  :cheers: I will add pictures as these things are finished.  :burgerking:
I started with an old particle board Gunsmoke cabinet that I picked up from a guy on Craigslist for free.  :applaud:
Replaced my desktop last year so the old tower was used for this project.
Here it is when I brought it home:
I scraped off all the artwork:
Painted it black (Combo of roller & rattle can):
Cut a piece of 1/2" playwood to mount the monitor on & bolted/screwed that into the existing mounting:
I then mounted my HP LP2065 LCD monitor via the vesa holes:
I then cut a piece of black posterboard to go around the monitor & glued that to the existing frame:
Then I got to work on the control panel. I went with your standard Street Fighter II layout:
Painted the CP flat black:
Picked up a set of cheap Logitech 2.1 PC speakers from Newegg. I got lucky & they were small enough to fit the existing speaker area so I just laid them in there. The subwoofer is at the bottom of the cab next to the PC tower.
I then used some 3M double sided tape to mount the volume control to a place where I can reach it:
Here you can see the underside of the CP, the USB hub I mounted in the front of the cab & the PC power switch above the hub. I am running Paradise Arcade Shop’s USB controller.
The keyboard & mouse are behind the coin door:
Here’s a shot of the subwoofer, PC tower & smart power strip at the bottom of the cabinet. I used the PC as the main power source:
Some shots of it turned on & running:
« Last Edit: January 24, 2011, 08:29:13 pm by MagicManPA »
  • Last login:December 13, 2023, 12:03:14 am
Re: My 1st cabinet build... (Picture heavy)
« Reply #1 on: January 18, 2011, 11:05:47 am »
Looks good! Maybe I missed it on first read, but what frontend are you using?
Looks like you could make that LCD rotate without a whole lot of work.
MagicManPA
« Reply #2 on: January 18, 2011, 11:08:07 am »
I'm running Mala.
Donkbaca
    • Slim built MAME/Xbox cab
« Reply #3 on: January 18, 2011, 01:46:01 pm »
good, clean job.  Aren't you glad you didn't just stick an x-arcade on it ;)
Garza
  • Last login:July 09, 2015, 10:53:29 am
« Reply #4 on: January 19, 2011, 02:50:07 pm »
Look Great! :applaud:
MagicManPA
Re: My 1st cabinet build... (Picture heavy) *UPDATE 1/24*
« Reply #5 on: January 24, 2011, 08:30:09 pm »
Put the red t-molding on tonight followed by the Mario doll my gf crocheted from scratch for me. She sells crocheted stuff if anyone is interested. ;)
Donkbaca
« Reply #6 on: January 25, 2011, 12:06:51 am »
A link to your gfs stuff? That is awesome!
MagicManPA
« Reply #7 on: January 25, 2011, 12:17:20 am »
She doesn't have a webstore or anything. Just sells to co-workers, friends, etc. Just listed a few auctions on Etsy tonight. She can make a lot of stuff.
http://www.etsy.com/people/Akrivos87?ref=ls_profile
jmike
  • Last login:June 26, 2023, 05:14:03 am
« Reply #8 on: January 25, 2011, 07:18:12 am »
Good job on the cab. How is the USB controller working out for you? I ordered one but haven't had a chance to test it out.
Congrats on the GF making you that awesome Mario. I saw someone make a scarf with Mike Tyson on one end and LIttle Mac on the other. any chance the GF can make one of those?
MagicManPA
« Reply #9 on: January 25, 2011, 08:39:10 am »
Seems like the USB controller took a dump last night. PAS has shipped me a replacement.
I'd have to ask if she could make 1 of those. PM me if interested.
