Author Topic: Paradise USB controller install  (Read 942 times)
MagicManPA
  • Last login:January 12, 2019, 04:35:43 pm
« on: January 12, 2011, 12:49:12 pm »
done
« Last Edit: January 19, 2011, 09:26:44 am by MagicManPA »
eds1275
  • Last login:May 03, 2024, 12:05:34 pm
  • Rock and Roll!
Re: Paradise USB controller install
« Reply #1 on: January 12, 2011, 12:53:26 pm »
You daisy chain the grounds together!
MagicManPA
« Reply #2 on: January 12, 2011, 12:54:43 pm »
Maybe I wasn't clear, I have the grounds covered. It's the other 2 prongs that I am unsure of...
Hoopz
  • Last login:February 09, 2024, 02:36:26 pm
  • Intellivision Rocks!
« Reply #3 on: January 12, 2011, 12:55:29 pm »
If you have "standard" micro switches, you wire the ground and the NO (normally open) contacts.  Here is a link to this website's menu and you can select the WIRING button on the left frame to get detailed pictures and more info:
http://arcadecontrols.com/arcade.htm
Not sure why the individual page doesn't like though.  Regardless, it's easy to pull up and read.
EDIT:  Fixed an error.  I screwed up....  :-[
« Last Edit: January 12, 2011, 01:07:24 pm by Hoopz »
BobA
  • What Me Worry?
« Reply #4 on: January 12, 2011, 01:05:16 pm »
I think that is NO (normally open) so it closes when you press the switch and passes the ground to the interface. ;)
« Last Edit: January 12, 2011, 01:09:51 pm by BobA »
Hoopz
« Reply #5 on: January 12, 2011, 01:08:59 pm »
Fixt!  I was trying to work and post.  Time to stop working...
8lords
  • Last login:January 20, 2011, 05:36:15 pm
« Reply #6 on: January 19, 2011, 09:13:52 am »
Yep, you only use the ground and the NO.
MagicManPA
« Reply #7 on: January 19, 2011, 09:26:34 am »
Already up & running, but thanks guys.
