Main > Project Announcements
Burgertime bartop-mini
IG-88:
Attached are those BT plans that I did a while back. Basically all I did was chop a full sized cab in half and then reduced the size by a third. Too big for what you are looking for probably but someone may be able to get a start from them. ;D
newmanfamilyvlogs:
.skp is sketchup?
I'll have to see if I can convert those to some format that my cad software uses. Can scale them / redraw them freely after that.
IG-88:
Yes, sorry, that is sketchup. You can get a free version easy enough. Keep in mind they are really basic and something I just threw together in a couple hrs.
Got a couple others too if you want them. Looks like a Tron, Asteroid (yes not plural, the 1973 machine) and a Gunfight.
opt2not:
--- Quote from: IG-88 on January 11, 2011, 07:56:01 pm ---Attached are those BT plans that I did a while back. Basically all I did was chop a full sized cab in half and then reduced the size by a third. Too big for what you are looking for probably but someone may be able to get a start from them. ;D
Wow thanks! A good starting point for me to fiddle with. :cheers:
IG-88:
No prob. I HAVE to find time this summer to knock a couple of these out. I just love those old 70's style cabs. Not to mention BT and Tron!
