Main > Project Announcements
First Mame Project (newbie)
bullrees:
I looked at the jpac to start with but I didn't have the 7600 available to me then. The wife seems to want a cocktail now so I'll be back in the same spot in the future with the same jamma harness and arcade monitor.
While the wide screen lcd was the easiest I like some vert fliers and pinball. It seems a tight fit but I'm gonna see if I take it out of the case and rotate it. I doubt it but we'll see.
Computer setup. (looks like a mess I know)
Larger pic
Mounting the PSU was the worst. I had to take it apart, drill holes in the back plate, screw the back plate in and then put it back together blind because I couldn't see what I was doing. I'm sure there is a better way but trial and error here.
Sound
I thought this would be easy also but curved plastic does not like to be forced strait. I won though.
Larger
Larger
Larger
jipp:
looking good. i too plan on using a 26" flat screen. i would rather have it mounted like yours but as its a after thought not being able to find a crt. i will have to install it vertical.. at least i have enough room for that.
and its great to see the kids standing at the cab.. memories they will have for a life time.
chris.
