Main > Main Forum
Button covers
Pages: << < (3/3)
lilshawn:
cut your ground to the admin buttons....
install another "enable" button out of the way that hooks the ground back up again.
press and hold enable and press your admin button.
ErikRuud:
--- Quote from: Vigo on December 30, 2010, 11:16:29 am ---Good Idea, as long as you don't mind mounting another switch.  :cheers:
You might want to make that switch a toggle switch though. You may find that having to push two buttons at the same time, at a distance farther apart than your armspan, could be an acrobatic act.
That's how I handled it.  I have a hidden toggle for the admin buttons.
DeLuSioNal29:
Interesting, I recently came across another topic where the guy hid the buttons in the lower coin door.
http://forum.arcadecontrols.com/index.php?topic=106027.0
But +1 on the vote for creating a toggle switch that you need to hold down in order to get the buttons to work.
D
katuuuz:
if you do decide to remove the buttons, you could buy these plugs from Happ:
http://www.happcontrols.com/pushbuttons/52621200.htm
Diewrecked:
Many thanks for all your responses guys!
It does seem that a second switch in series for these three buttons is the way to go - what a good idea! That's why I like asking questions on this forum :)
Thanks again chaps!  :cheers:
Pages: << < (3/3)
Go to full version
