Main > Project Announcements
mini/bartop GT 99 (advice needed)
pharoah007:
I made myself a "saw board" It was Quick and easy to do. This allowed me to clamp the saw board down on the wood and cut right to the line thus eliminating the need for sanding :) I used my Jigsaw to do the rest. Jigsaw part was time consuming but did a good job.
now to hunt down a router and T-molding cutter
pharoah007:
Got the T-molding and slot cutter in the mail today.
Now to cut some slots!
BobA:
Make sure the cutter is in the right way. Some people have put it in upside down and the end result is smoke and a very hot cutter. When the cutter rotates the teeth are driven by the router into the mdf point first. It should cut like it is going thru butter. :D
pharoah007:
--- Quote from: BobA on March 31, 2011, 09:58:16 am ---Make sure the cutter is in the right way. Some people have put it in upside down and the end result is smoke and a very hot cutter. When the cutter rotates the teeth are driven by the router into the mdf point first. It should cut like it is going thru butter. :D
Roger.
all done cutting, worked like a charm :)
