May 08, 2024, 06:49:18 am
i would probably just get a set with an assortment of bits. Something like this:http://www.amazon.com/MLCS-8377-Router-Carbide-Tipped-15-Piece/dp/B000FJRN8S/ref=sr_1_1?ie=UTF8&qid=1292500596&sr=8-1Should have everything you need for your purpose and will be cheaper than buying all the bits individually
I bought a pack like this and the only one I used was the flush trim bit. Wound up buying the slot cutter and a larger roundover bit to make the Williams style control panel front for my bartop.I say get the bits individually since so many of them in the kits are made for creating ornamental cuts for trim and storage cabinets.You also have to know your collet size. Many 1/2" collet routers will work with 1/4" bits, but not the other way around. If you got a 1/4" collet router, the bits in the link won't fit.
