Author Topic: Where are your USB ports in your cabinet?  (Read 3765 times)
« on: December 09, 2010, 08:05:05 pm »
I've been searching for a USB hub that will mount into my cab's panelling. I've found there's not a whole lot of options if I want to keep a clean look. I want access to 4 USB ports on the outside of my cabinet without visible wires. I found the in desk hubs like Belkin makes ( http://www.belkin.com/IWCatProductPage.process?Product_Id=369283 ) but I don't want a hole in my cab around the hub. I finally stumbled across these couplers ( http://www.l-com.com/item.aspx?id=8159 ) that I think will work great, just wish they were a 4 port hub. So what are you using?
gryhnd
Re: Where are your USB ports in your cabinet?
« Reply #1 on: December 09, 2010, 09:16:54 pm »
Painted this black:
And installed lower left, above the CP:
Completed: No Name Upright
« Reply #2 on: December 09, 2010, 10:41:09 pm »
I just bought some cheap extender cables, drilled/chiseled a hole to match the size of the plug, mounted it and epoxied it in place. Looks great, but is pretty inconspicuous.
CapriRS302
  • Last login:June 02, 2011, 01:26:47 pm
« Reply #3 on: December 10, 2010, 09:22:56 am »
Ibought a standard 4 port usb hub, and just double sided taped it under my control panel.  You cannot see it, but it is easy to get to when I need it.
« Reply #4 on: December 10, 2010, 10:51:31 am »
I open the coin door on the rare occasion I need in the machine. I don't want to make it too easy to hookup a mouse and keyboard, but if your wanting to hookup some controllers, I can see needing them.
megrog2
  • Last login:June 02, 2016, 11:53:52 am
« Reply #5 on: December 10, 2010, 01:04:14 pm »
You could use something a multi function drive bay device for a computer and just figure out a way to mount it cleanly somewhere. www.Frozencpu.com has tons of different ones to choose from
ahofle
    • Arcade Ambience Project
« Reply #6 on: December 10, 2010, 01:34:38 pm »
Two of these on the front of the control panel:
http://www.markertek.com/Connectors-Adapters/Data-Connectors-Adapters/USB-Adapters/Switchcraft-Corporation/EHUSBABBX.xhtml
They are simple to install since you only need to drill a hole.  No cutting/routing out square pieces.
Dervacumen
  • Last login:February 13, 2019, 10:11:11 pm
  • Home of Three Squares dice game
    • Beaker Games
« Reply #7 on: December 10, 2010, 03:05:20 pm »
I bought something similar and didn't use it.  Instead I just hooked up a keyboard via usb and keep it inside the cabinet, accessible by opening the coin door and pulling it out.  I don't use any controllers that would require USB.
Bringing to life a child's imagination.
gazz292
  • Last login:January 22, 2022, 12:00:01 pm
« Reply #8 on: December 10, 2010, 08:02:34 pm »
i took the double front usb ports from the case the pooter came in,
then i took a spare happ push button, removed the button bit, and dremeled the usb ports square plastic surround till it was round, and sat inside the button housing,
then i just mounted the button/usb port on the side of the cab, of course for a 4 port jobbie you'd need 2 buttons,
nick3092
  • Last login:March 22, 2022, 03:57:28 pm
« Reply #9 on: December 11, 2010, 09:29:01 am »
That is also what I did.  Along with my NES, SNES, N64 and GC ports.  I haven't gotten any further on my cab since I took this picture, but you get the idea.  I wanted nice clean flush mounted ports.  When I epoxy them in, I'll use some filler around the front of the ports before I paint it to give it a nice, seamless look.
« Reply #10 on: December 11, 2010, 09:36:24 am »
Have you visited retrousb.com? I love using classic controllers, but I like the idea of a univeral port on my cabinet. I'll be converting my classic controllers to have usb connections.
Blanka
« Reply #11 on: December 11, 2010, 09:46:19 am »
They are inside the cabinet. No idea why you would want to have access to them.
nick3092
« Reply #12 on: December 11, 2010, 09:54:44 am »
Yeah.  And actually, I bought pairs of their NES/SNES/N64 adapters.  But I didn't want to hack up any of my controllers, and I didn't want to have to have extra converters laying around.  Plus this way the USB HID "controllers" are always present, so I have consistent joystick ID's when it comes to assigning controllers in the various emulators.  My main interface is a GPWiz 40 and I found windows likes to renumber the joysticks when you plug/unplug new ones in, screwing things up.
I went with Raphnet's interfaces.  He sells some premade adapters, but I just ordered the PCB kits and soldered everything up myself.  He has a 4 player (S)NES kit, so I was able to connect both my NES and SNES ports up with one USB cable, and the N64/GC kit supports one of each controller, so I only needed 2 kits for those 4 controllers.  He also has an Intellivision conversion kit that I would like to do once I get my hands on a spare and/or broken Intv.  That one will have to have to remain USB.
nick3092
« Reply #13 on: December 11, 2010, 09:59:15 am »
For me personally, I plan to use them for plugging in additional controllers, plugging in a USB thumb drive/USB HDD to install additional software, etc... without having to open up the access door to the PC and plug things in there.
Blanka
« Reply #14 on: December 11, 2010, 10:38:33 am »
I use remote access and an occasional Bluetooth keyboard for that. Way more convenience than attaching al kind of stuff to your cabinet.
ArcadeNerd
  • Last login:July 19, 2021, 10:16:00 am
  • When's it my frickin turn to play?!?
« Reply #15 on: December 11, 2010, 11:25:42 am »
I use the same thing as ahofle except the Neutrik brand (seems cheaper).  Super easy to use.  Just drill a hole and screw it in.... bam you're done.  They look pretty slick too.
http://www.markertek.com/Connectors-Adapters/Data-Connectors-Adapters/USB-Adapters/Neutrik-USA-Inc/NAUSB.xhtml
Todd H
  • Last login:February 17, 2024, 12:58:49 pm
  • It's Gameday!
« Reply #16 on: December 11, 2010, 01:11:42 pm »
nick3092
« Reply #17 on: December 11, 2010, 02:06:00 pm »
I mounted one of these below my control panel out of sight.
http://www.monoprice.com/products/product.asp?c_id=103&cp_id=10307&cs_id=1030701&p_id=226&seq=1&format=2
I used that exact same hub inside my CP (since it's modular) to plug in the trackball, analog flight stick, and to get +5 for my p360's.  On a few occasions it got a little goofy, and didn't recognize anything is plugged into it.  i found an easy fix is to pull the cable out of the back that goes to the PC, but for the most part it works fine.
jipp
« Reply #18 on: December 14, 2010, 08:46:13 am »
Hi. i have a question.  i too plan on having usb ports at hand.  i plan on mounting them too the wood panel that will be above and below the bezel/plexi. they are for the for the USB NES controllers, and thumb drives.  I bought a 4 way hub for 2.00 to use for the NES controlers.  so i have zero problems hacking it up to put in my wood panel.  so here is what im wondering.  i will have have 1 cable for each: trackball, ipac2, spinner, keyboard, mouse,and aimtrack guns.  so when do we need to have power added to the USB.  I ordered a 10 port usb hub that has its own power supply.  could i got away with just another cheap 4 way hub if I need more ports?
i think i have enough ports on my computer i wont need the 10 port hub on my current project.. i  bought the hub with its own power supply for my next project which will have LED stuff and figure id need power for it.. and if i do need more ports i can use it in my current project..
thank you.
severdhed
  • RIP Dinosaur Hippo
« Reply #19 on: December 14, 2010, 10:04:16 pm »
i generally dont need to have usb ports on the outside.  on my showcase cabinet, i do have two usb ports however so that i can plug in my guncon 2 guns into my playstation 2 that is inside the cabinet along with my pc.  i cut a piece of plexiglass and drilled/cut a few holes in it and mounted it to the inside of the coin door, so that the ports are accessable through the coin return openings. i need to paint this plexi so you can't see through it, but i was in a hurry the night i made it...
these are connected to some usb extension cables that run back to my playstation 2.  i can also plug them into the PC if i wanted to use my guns with mame (pain in the butt to get working reliably)  this way they are easy to access, but don't stick out like a sore thumb. (there are also two video ports for the guncons, and on the other side is a 1/4 jack to connect my reload pedal)
« Last Edit: December 14, 2010, 10:06:11 pm by severdhed »
