Main > Project Announcements
planning Donkey Kong bartop... need yer halp
stuckpixel:
The 60-in-1s use a VGA connector, so you really don't have a JAMMA compatable cab - unless the jamma board you are using happens to do video via VGA header as well (most don't).
Given the cost of the 60-in-1s, why wouldn't you just buy an mini-itx board and a hard drive? It'd be cheaper - and you'd have a significantly more flexible machine. I got my motherboard with an atom processor for less than 50 bucks, and HDs are dirt cheap these days.
Donkey_Kong:
--- Quote from: ChurchOfSolipsism on December 09, 2010, 05:41:45 pm ---This $%&/(%"!§"$ computer just deleted my almost complete post :angry: so bear with me if I keep it as short as possible the second time around.
A long time ago I got into the habit of highlighting and copying long posts, emails, etc...before clicking that send/post button. This way if you lose it you could just paste it back. It's pure habit for me now and I'm a lazy sob, if I type in just a few words I will copy it just in case.
highlight text> ctrl+c (copy) .... position cursur> ctrl+v (paste)
Good luck on the bartop machine!
ChurchOfSolipsism:
--- Quote from: stuckpixel on December 12, 2010, 03:25:52 pm ---The 60-in-1s use a VGA connector, so you really don't have a JAMMA compatable cab - unless the jamma board you are using happens to do video via VGA header as well (most don't).
Hmmmm, now you've got me thinking... if I can't even connect them to a cheap TV, what's the point... cheers for pointing that out to me.
--- Quote from: Donkey_Kong on December 12, 2010, 03:49:34 pm ---
Yeah that's what I do every time, just not in that particular instance... oh well. Thanks anway.
jipp:
i do the same thing if its anything over a paragraph.. iv lost way to many posts cause of windows back in the day.. now its just habit.
ChurchOfSolipsism -
good luck on your cab. i like the idea of the 60-1 boards for people who want to keep it simple.. like if i was to make a cab for my step dad.. i would go that rout. or id be on the phone trying to fix something he cant figure out. laughs.
chris.
ChurchOfSolipsism:
--- Quote from: jipp on December 12, 2010, 04:08:40 pm ---
ChurchOfSolipsism -
chris.
Hahah- hold on, did you just call me simple? I don't appreciate that at all!
