Main > Main Forum
Gamepad Emulator why not?
gonzo90017:
Are you running it through AtomicFE? If so, it has an option to launch a program before and after you launch a game.
Haggar:
Yes I'm using atomic FE.
I've used that option, but when i exit from the game I've launched, the system hangs on the ppjoy window and I have to hit the CLOSE button and confirm with YES. So I have to use mouse/keyboard to do that on the cab :(
gonzo90017:
You could make an Autoit script to close ppjoy when you exit the game.
Haggar:
Great suggestion.
I've tried on a normal PC and it works. Now I have to try this stuff on the cab.
This tool is very very nice.
Thank you :cheers:
tekopaa:
Can anyone solve EA SPORTS NHL 2007-2009 problems with PPJOY virtual joystic. When i start the game joystick moves byself when in game it works but not in menus????... problem stop if disable virtualjoystick from device manager.. Ihave tested with other games no problem there??
