Main > Everything Else
Eee PC
SavannahLion:
--- Quote from: cotmm68030 on December 08, 2010, 09:59:33 am ---Seen this myself (at least i recall it was the same set of symptoms)
Used the following to recover it:
http://wiki.eeeuser.com/howto:recoverfrombrick
Tried it with a spare SD Micro in a USB adapter. It apparently didn't work except the fan spins up/down now. The battery light stopped flashing (most likely it's above 10% charge now that it's been plugged in for a while) That was a lot more than before. Tried to reset the BIOS as well and that failed too. What's interesting is that I noticed the HDD light isn't coming on at all. I didn't really think anything of it at first but now....
Interestingly, one of the BIOS updates addresses the exact symptoms I'm experiencing. Whether they're caused by the same problem, I haven't the foggiest.
I would like to try and hunt down on my other USB sticks with a status light and see if there actually any activity at all on the USB port or if the fan cycling is just a coincidence. Unfortunately, I think this one is a FAIL. I had two emergencies take out two days out of the four I had this Eee. So that was time lost and tonight I have to draft some important papers so that takes time away from this process.
I spoke with the owner and she seems to think it's still under warranty. So I'll hand the Eee back to her and she can, hopefully, get it repaired wherever she got it from.
Oh well. Back to drafting papers and building cabs. :dunno
Navigation
[0] Message Index
[*] Previous page
Go to full version
