Author Topic: Jamma Board (xxxx in 1) VS Mame machine  (Read 16058 times)
racecar
  • Last login:June 29, 2012, 01:36:27 am
« on: November 17, 2010, 11:39:56 pm »
hi all just wondering about the two..
i see on the jamma website that you can buy these jamma boards for arcade cabnets, i was wondering the following
any up side to having this instead of a Mame machine
which plays better, eg speed wise, freezing etc??
which has less errors??
thanks all just getting as much info with everything before i look at getting a machine done
link to what im after
saint's note - no links to illegal products please.
« Last Edit: November 18, 2010, 12:44:25 am by saint »
BobA
  • What Me Worry?
Re: Jamma Board (xxxx in 1) VS Mame machine
« Reply #1 on: November 18, 2010, 01:10:56 am »
It is mame on a PC board so there is no real difference except that it is an old version with a underpowered CPU and you have less leeway to make changes because it is prepackaged for you.
Don
  • Last login:March 26, 2024, 04:39:03 pm
« Reply #2 on: November 18, 2010, 08:18:44 am »
The benefit of the jamma board would be that it will boot straight up into a menu for selecting games, unlike windows which you have to try and hide etc.
And the benefit of the PC would be control over what games, menus, controls etc, along with the option to add more content if required
P.S. i've never used a xxx-in-1 jamma board so just going off what i've seen
BobA
  • What Me Worry?
« Reply #3 on: November 18, 2010, 09:18:16 am »
The jamma board uses either windows 2000 or XP so it can hide the windows boot up.  Again they have just done the work of hiding windows and packaging it with a front end.  You can do the same with your own PC and MAME.
racecar
« Reply #4 on: November 18, 2010, 05:23:14 pm »
oh ok thanks for that, i dont mind if i have to boot up and i see windows at all tbh
if theres no real difference i think im better off using the newest version of mame etc...
will games run better if there on the new version of mame? (making sure i have the matching rom of course)
or are they better on the older version jamma board
BobA
  • What Me Worry?
« Reply #5 on: November 18, 2010, 05:53:54 pm »
If you have limited CPU resources you are better off with an older version of mame.  That said it is nice to be able to choose what mame you are going to use and get the matching ROMs.  The jamma board locks you in to ? version of mame it can be reprogrammed but is alot harder to work with than a PC that you have full control over.
FrizzleFried
  • Last login:May 30, 2023, 01:14:24 pm
    • Idaho Garagecade
« Reply #6 on: November 18, 2010, 06:10:39 pm »
As most know here,  I have no problem with most of the multi's...
...that said,  the XXXX-in-1's are ---steaming pile of meadow muffin---.  I've dicked around with 2 different versions and they are ---steaming pile of meadow muffin---.  They are under powered running an older version of MAME with much much much less flexibility. Plus there are multiple reports you get USED ---steaming pile of meadow muffin--- (of the 2 I got,  1 was OBVIOUSLY using used components...right from the distribution company!)...
grantspain
  • Last login:Yesterday at 04:47:48 pm
« Reply #7 on: November 18, 2010, 06:24:39 pm »
i bought 4 x 1072 in 1 pcb and they are excellent
pentium 4 2.4g with 80gb hdd-no lag,sounds all ok-i am quite impressed tbh
racecar
« Reply #8 on: November 18, 2010, 07:01:46 pm »
oh really, so the games has no lag?? can u change button layout for a game if its not correct?
a link would be good to see what one you got
BobA
  • What Me Worry?
« Reply #9 on: November 18, 2010, 07:09:28 pm »
Links to illegal boards are not allowed.
racecar
« Reply #10 on: November 18, 2010, 09:59:42 pm »
sorry i didnt know they were illegal
anyway back to the board talk, i think i understand
would hate to spend the cash and find out they have lag and button input cant be changed...
  • Last login:October 20, 2023, 11:39:06 pm
« Reply #11 on: November 19, 2010, 01:05:45 am »
Also, there are select games on the multiboard that are emulated poorly.  Sound being the main issue.  So if you're looking for a close to faithful emulation, MAME is the way to go, not the multiboards.
matsadona
« Reply #12 on: November 19, 2010, 05:02:48 am »
Isn't the obvious advantage with the xxx-in-1 box that it is equipped with a JAMMA interface?
I.e. that you don't need to mess around with keyboard and video interfaces etc.
As others already stated, it is a MAME PC but with restrictions in what you can alter.
The ones I have used is similar in performance (as long as you play the old classics) even though the CPU and RAM is obsolete compared to a new PC.
So, if you can live with the games and frontend that comes with it and prefer a simple and convenient installation - then the xxx-in-1 box is for you.
racecar
« Reply #13 on: November 21, 2010, 05:26:20 pm »
thanks... ill just start saving the cash and figure something out  :)
racecar
« Reply #14 on: November 23, 2010, 05:44:23 pm »
question, with a multi board can button layout be changed in game?
also is there a list which multi boards have poorly ported games?
FrizzleFried
    • Idaho Garagecade
« Reply #15 on: November 23, 2010, 05:54:13 pm »
Stop being lazy and build your own MAME system... you won't regret it...
WhereEaglesDare
    • My HomePage
« Reply #16 on: November 23, 2010, 06:08:39 pm »
I have a question and I am not trying to walk over a line, but I have an "underpowered PC"  that I was planning on using on a Vertical setup eventually.  Is there a xxx-n-1 that can just be downloaded and loaded on a HDD pre-setup etc???
Not asking where to download it, just if it exists to be downloaded?
« Reply #17 on: November 23, 2010, 06:09:47 pm »
Another reason to go with your own Mame system is that those "xxxx in 1" boards always seem to come with some f'ugly game menus.  I personally can't stand looking at that multi-coloured font, grid-based game selection and blue-ish gray background.  :puke
TOK
  • Last login:January 24, 2024, 05:14:24 pm
  • The Game Always Wins
« Reply #18 on: November 23, 2010, 06:56:25 pm »
Not sure about that, but it is very easy to use an older version of MAME along with MaLa or something.
My bartop is a 933mhz Pentium 3. I think I'm using .67 on there and it runs all the golden age stuff great. Its not gonna run NFL Blitz, but some newish shooters like Mars Matrix work fine.
abaraba
  • ---Perm Ban---
  • Last login:July 30, 2011, 08:42:58 am
« Reply #19 on: November 23, 2010, 08:14:52 pm »
Yes, and no.
First, we have to split these boards to x86 and ARM based PCBs:
- PC (x86) based boards are not "underpowered" computers, they run AdvanceMAME, so you do not want or need this.
- ARM boards like 39-in-1, 48-in-1 and 60-in-1, they run vertically oriented games, so this is what you are talking about.
Unfortunately, while these PCBs are "underpowered", they are not PCs, so this is of no use to you again, and If you were to make your own ARM based PCB you would want something like this (http://www.gumstix.com/):
However, once you realize the cost of this very cool "Computer-on-Modules" and similar 'empty' PCBs is more than actual 60-in-1, then making "your own" does not make much sense any more. What's more, these boards have poor sound, amazingly terrible in some games like Gyruss & Scramble, so you are much better off with some underpowered PC and VAntAGE (Vertical Antiquated Arcade Game Emulator), where even with old 486 PC you would have more games supported and better sound, and if your computer is anything at, or above pentium 233MHz then you can run MAME too, and with it most, if not all, of the '80-'90 games. Both, better price and emulation quality you get with PC based setup, and if you make it yourself then you also get a lot of customization options.
PC based xxxx-in-1 are not really "dumped" as normally arcade ROMs are, they are 'hard drive' images, they are big and they contain just plain PC software you can download, install or copy/paste separately. I would not expect to find these HD images together with other arcade ROMs, but, on the other hand 39in1 and 48in1 are actually even emulated in MAME, so you could expect to find these for download wherever the other arcade ROMs are.
« Last Edit: November 23, 2010, 08:27:53 pm by abaraba »
---Perm Ban, again---
WhereEaglesDare
    • My HomePage
« Reply #20 on: November 23, 2010, 08:51:46 pm »
indeed
but my problem with older versions, in my experience, the sounds is screwed up in older versions of MAME.  Donkey Kong for example
TOK
« Reply #21 on: November 23, 2010, 09:54:43 pm »
From what I've read, they're screwed up on these boards too.
Have you run an old version with the /samples in the folder? I don't know if they're 100% accurate, but I've never noticed anything that felt wrong about them.
WhereEaglesDare
    • My HomePage
« Reply #22 on: November 23, 2010, 10:25:22 pm »
no i have not....  i should though!  Thanks for the tip
racecar
« Reply #23 on: November 24, 2010, 01:25:43 am »
MAME MACHINE it is!  8)
more options, and updated more... i think this will be better
thanks guys, now just to look at pc parts to use
