Main > Main Forum
PC Spec Question
flashiv:
Very true lilshawn, lots of people don't know that on-board video does take away from your memory.
smalltownguy:
Lilshawn's comment only applies if the video is using shared video RAM. Most systems with on-board video don't. At least not in my field experience. For example, at my workplace, we have approx 100 workstations, ranging from an Intel Celeron 1.1 setup to a Core2 quad 2.8 that I just built last May. All have on-board video except 1 workstation utilizing a dual monitor setup - that system has a separate PCIe graphics card.
Out of the rest of the population, I have only inventoried 2 systems that are using shared video RAM - both are AMD rigs.
MAME won't benefit much with a multi-core processor unless it's a recent version, and even then you won't see much improvement. I'm perfectly happy with my P4 3.2 HT setup. No, I cannot run Blitz, but neither can the guy with the latest and greatest Octo-core madness either. MAME's development has not really moved much into the multi-threaded realm yet.
bkenobi:
--- Quote from: smalltownguy on November 18, 2010, 11:12:50 am ---Lilshawn's comment only applies if the video is using shared video RAM. Most systems with on-board video don't. At least not in my field experience.
You have some unique experience then. Since the inception of onboard video (essentially), the video RAM is segmented off of the system RAM through a BIOS setting. I have an OLD system (P3 or P4 I think) that has 256MB or system memory. I can select up to 128MB of video memory in BIOS. That would be HORRIBLE, but possible. Anyway, unless onboard video has changed architecture in the last 2-3 years, memory is still shared.
flashiv:
--- Quote from: bkenobi on November 18, 2010, 11:27:04 am ---
I have to say that my experiences match bkenobi's also. We have 70 machines and all have shared video RAM.
newmanfamilyvlogs:
Even more ironically, the two systems I can think of that I've used with onboard video that DIDN'T share ram (ie, they had their own onboard dedicated ram) were AMD systems.
