Author Topic: Help Me Figure Out Where These LED Clusters Come From  (Read 1465 times)
brian23
  • Last login:September 07, 2011, 03:52:01 pm
« on: November 16, 2010, 04:28:01 pm »
I bought these LED cluster lights with resistors and +5V. They are powered via the PC molex connector. Now I have a friend that is building his own arcade machine after I built mine about 6 years ago and my memory is shotty. Can anyone tell me where I might of obtained these LED cluster lights? Thanks in advance
Dazz
  • Last login:March 30, 2024, 10:34:39 am
  • HyperSpin Team
    • VPUniverse
Re: Help Me Figure Out Where These LED Clusters Come From
« Reply #1 on: November 16, 2010, 04:34:47 pm »
brian23
« Reply #2 on: November 16, 2010, 04:55:01 pm »
Awesome. And these come with the clips shown the picture?
Dazz
  • HyperSpin Team
    • VPUniverse
« Reply #3 on: November 16, 2010, 04:57:33 pm »
No, the clips should be attached to the base/light bulb holder.  If you remove the light the base should remain.  You then just slide the light into the base.
brian23
« Reply #4 on: November 16, 2010, 06:05:54 pm »
hmm, I seem to remember that the clips came with the LED.
MidnightClubbed
  • Last login:April 23, 2016, 09:10:06 pm
« Reply #5 on: November 16, 2010, 06:19:56 pm »
Did you check www.ultimarc.com ?
Andy supplies 5v led's with clips that look fairly similar so could be those?
brian23
« Reply #6 on: September 07, 2011, 02:06:07 pm »
I found out what these are... they are Happ T 3 1/4 Wedge Sockets.
See here - http://retroblast.arcadecontrols.com/articles/coindoor.html
