Author Topic: Using my arcade's joystick on my PS3.  (Read 1651 times)
Suikodan
  • Last login:February 03, 2024, 07:00:40 pm
« on: November 16, 2010, 08:46:58 am »
Hi,
My cabinet is finally working for MAME. However, I would like to use it on my PS3 for SSF4 and MvC3.
My joysticks are connected to an IPAC2 but I can remove the plastic connector so I could connect it to something else.
My question is, can I "hack" a PS (or PS2) controller and connect it to the PS3 using a PS-to-USB connector?
  • Last login:May 06, 2024, 04:33:26 pm
Re: Using my arcade's joystick on my PS3.
« Reply #1 on: November 16, 2010, 08:59:59 am »
Suikodan
« Reply #2 on: November 16, 2010, 09:49:35 am »
Thanks for the reply. Can I ask some questions about it?
1- Does one board support 2 joysticks?
2- Will the PS3 recognize it? IIRC, there was a firmware update that was supposed to cancel all "custom" controller.
« Reply #3 on: November 16, 2010, 09:54:06 am »
1) No, you would need 2 boards for 2 sets of controls.
2) Don't know.  You could probably check over at the shoryuken forums to find out.
BurgerKingDiamond
« Reply #4 on: November 16, 2010, 10:28:40 am »
damn, that's a good point about the new update. I forgot about that. I have a cthulhu, but I don't ever bother to use it on my PS3. I did try it a couple times though when I first got it. It worked great then. If I can get the motivation I'll test it out and let you know.
« Last Edit: November 16, 2010, 10:31:27 am by BurgerKingDiamond »
-Welcome to the Fantasy Zone.
dandare
« Reply #5 on: November 16, 2010, 04:49:53 pm »
I'm putting together a second candy style cab at the moment, pretty much just to play MvsC3!  i have a cthulhu board and a hacked ps1 controller. the cthulhu is a fantastic board, and so easy to set up if soldering is not for you.
was working fine today with the current ps3 update.  Hacking a pad is a fair bit cheaper though. either way you just need a usb switcher, or some terminal blocks to wire your controls up to two systems (ps3 & pc/mame)
