Main > Everything Else
rubik's cube: Where do I go from here?
<< < (2/4) > >>
hyiu:
after you get the bottom completely right, and then the lower 2 levels correct, I believe you need to use formulas to solve the rest....
check youtube for videos...
HaRuMaN:
Peel the stickers off, replace in correct locations.  Duh.
HanoiBoi:
--- Quote from: HarumaN on November 15, 2010, 01:10:22 pm ---Peel the stickers off, replace in correct locations.  Duh.
Never peel the stickers.  If you MUST cheat, pop the pieces out.  Stickers are never the same after.
Thenasty:
Do it right, right here
Gray_Area:
1980 - Pac-Man and Rubik's Cube.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
