Main > Project Announcements
Here Goes................
MAME TIME:
the glass is tightly fitted into the groove, im in the process of making some clips to hold it down. the Control panel was a pain in the butt, the original doesn't give you much room to work with. I had to remove the laminate as it was badly damaged.try and take more pics,hey leapin which monitor did you go with a crt or lcd, because i tried to fit a lcd and it was just too long
opt2not:
Good call on the CRT.
MAME TIME:
Some new projects in the works. Question has anyone done a dual mame redtent, i've been looking around and haven't seen one yet. that project should be interesting....
check it out
jipp:
looks like you been busy. nice work on the cocktails. i can say i never even thought about building one of them.. but now one of them would not look half bad out in the living room. heh. anyhow.. i can say iv never seen a red tent before. its a interesting idea.. im guessing two monitors and you play the other person.. thats the concept right or are the separate.. one game per side.. seems silly not to have them connected tho. but i guess if you needed to save space in your arcade that may of been a good alternative.
anyhow look forward to see what happens with the red tent.
chris.
BlasterMaster:
Jealous about your Nintendo VS Red Tent, been looking for one to get for years can never find them for less than 500 dollars.
Very Interested to see what you do with it, just dont change it to much. Have fun.
