Main > Project Announcements
Vigo's SNES. Classic console gaming on any TV.
Donkbaca:
Man I CANNOT find that motherboard of yours, or one similar for under a hundred bucks. Gonna have to keep my spidey senses tuned
Vigo:
I don't see it around either ??? I hope it's not discontinued...Let me do some digging and I let you know if I can find anything.
Donkbaca:
That's okay. The way I figure it, if you win the ipad2, you won't have time for this, so I'll just take this thing off your hands later ;)
Crono22:
AFIAK IONITX-C-U has been discontinued although you can find refurb units on ebay. When soldering the controller to usb pad. Where did you get a wiring diagram for it?
Vigo:
Thanks for the info! Thats really too bad it's getting discontinued....its a good board.
As far as the wiring diagram goes, I didn't need one, It was really straightforward once I decased it. Each set of leads for each controller port just needed to be matched in exact order. There is a set of 4 leads, then followed by a set of three leads for each port. I just soldered a wire between each lead like below
decased USB adaptor
______
|1----a|
|2----b|
|3----c|
|4----d|
|5----e|
|6----f|
|7----g|
back of SNES port
|---765-4321------abcd-efg---|
So the wires ran from 1 to 1, 2 to 2, a to a, etc.
hopefully that makes sense!
