Main > Main Forum
Severe Ghosting problem with J-PAC
ilpappa88:
Hi all,
I’m experiencing the same exact issues here but have a doubt on how to wire the 100nf capacitor. Would anyone be able to help me out?
Many thanks
Zebidee:
Suggest you connect the 100nF (104) capacitors across the switches active and ground terminals. Probably easiest to solder them directly onto the microswitches if using standard cherry-type.
100nF (104) are typically available as ceramic, either flat disc (older) or monolithic, and they are non-polarised (orientation doesn't matter).
