Main > Project Announcements
My "Tied To The 90's" Cab or: How I Learned to Stop Planning and Love the Router
Pages: << < (6/6)
Nephasth:
--- Quote from: push2reject on March 30, 2011, 10:20:20 pm ---One idea I had:
I was thinking about trying to install a Fushigi Ball in place of a standard trackball.  They have both glow-in-the dark and acrylic-over-metal balls.  They are 3" big per the website.  20 dollars @ Wally World and no shipping.  What do you think?  Has anyone tried this?
Interesting idea. I wonder what the acrylic over metal would look like LED lit from underneath...
BobA:
To quote the faq "Each FUSHIGI is hand made and polished therefore making every FUSHIGI ever so slightly unique to itself. "  If this is the case it might not have the tolerance required to give you constant contact with the rollers in a trackball.  I guess the only way to see how it rolls is to try one. It would look great if it works :D
push2reject:
--- Quote from: BobA on March 30, 2011, 11:47:39 pm ---To quote the faq "Each FUSHIGI is hand made and polished therefore making every FUSHIGI ever so slightly unique to itself. "  If this is the case it might not have the tolerance required to give you constant contact with the rollers in a trackball.
Sorta...  I just got back from Walmart.  I pulled one out of the box in the aisle and I'm glad I did.  It is a metal ball in cloudy plastic with what were clearly casting marks.  The ball had a molding seam all around the circumference with additional seam on one side from what I assume is a secondary casting (the metal ball inside would need to be suctioned in place on an arm while the first pour took place)  I looked at it for about 20 minutes figuring out how it was made.  I figured it would need to be sanded and polished.  On top of that it didn't have a clean or smooth feel to it like my ball has.  It was almost a bit tacky.  It's not "hand polished" its wiped down and stuck in the box in.  I'll pass until I see it in the 5 dollar bin.
I was so hopeful it would be cooler looking.  I'll likely order a black ball from Bob Roberts.  Anyone have the correct link to his site?  There appears to be a couple of versions.  I keep finding older ones.
mgb:
http://www.therealbobroberts.net/
SNAAKE:
lol awesome thread title. reminds me I still need to watch drstrangelove on blu ray.
cabinet looks good. what kind of hdtv is that anyway?? looks like those "samsung slim crt".
Pages: << < (6/6)
Go to full version
