Main > Project Announcements
Galaga Bartop (99.9 percent done with pics) Update 11/16/2010
BobA:
Now that it is running it is time to finalize the to do list.
Mount Power supply (strapping) DONE
Mount marquee light (HD double sided tape used to mount touchscreens) DONE
Mount back panel with hinge and lock probably add some wood or mdf stops DONE
Cut and install plexi for bezel DONE
Cut and install plexi for marquee DONE
Artwork for marquee, side and control panel. DONE
This is the last little bit that always seems to take the longest.
Have to go play some Galaga. :cheers: :cheers:
Rick:
--- Quote from: BobA on November 11, 2010, 04:00:34 pm ---This is the last little bit that always seems to take the longest.
We'll check on you in a couple months, to see when you're ready for your next update.
BobA:
Hopefully it will not be that distracting since I have a full featured bartop with MAME and other emulators. This unit is actually a present for a family friend so I had to make sure I got a jump on it to be finished for Christmas ;D ;D
Rick:
--- Quote from: BobA on November 11, 2010, 04:12:35 pm ---Hopefully it will not be that distracting since I have a full featured bartop with MAME and other emulators.
You're the lucky one. I have promised myself I won't wire up the joysticks and buttons until the entire cab is ready. Let's see how long that lasts.
Bender:
looking sweet!!! It's like a twin of one I built
I have art for the Marquee, side, CP and Bezel PM me the dimensions and I think I can hook you up
