Main > Project Announcements
First Project: MegaTokyo MAME!!
Aithos:
--- Quote from: Lo_Wire on October 29, 2010, 02:57:16 pm ---Find another hobby dude...
Dont be hassling Andy, Ipacs' are top notch.
:banghead:
Aithos:
--- Quote --- No one cares :cheers:
You apparently did.
Aithos:
from the other thread: http://forum.arcadecontrols.com/index.php?topic=100074.msg1133311#msg1133311
--- Quote from: AndyWarne on October 29, 2010, 01:54:29 pm ---Apology fully accepted, thanks..
Andy
move along please.
JustMichael:
--- Quote from: Aithos on October 29, 2010, 01:18:10 pm ---I'm only pulling the monitor out so that I can strip and paint inside and out. It isn't painted inside at all and I would like to at least spray it black, I sure can't do that
without yanking the monitor out. It also makes the cabinet less heavy so I can get it up from my garage and into my apartment, I don't live in a house and I have stairs to go
up to make this work.
I am glad you are going to paint the inside of the cabinet. People seem to forget that paint helps protect and stabilize the wood. Yes, removing as much as you can from the cabinet will make it lighter but I would still recommend an appliance dolly and at least one big strong friend. If you don't have the dolly they can be rented for the day for around $10.
MikeyMerse:
It's not in the nature of the hobby or the culture of BYOAC members to turn people away. He has already admitted he was mistaken, apologized, and it has been accepted by many. It also takes a big man to do that and then remain here after the incident.
On topic: I like the Sanwa JLF's. I customized it with nylon washers around the screws in the restrictor plate so I could rotate them on the fly in 2 seconds. Just make sure your control panel is hinged or you can reach them through the coin door. Good luck with the project, I'll be watching.
