Main > Project Announcements
PIN CRAZY build with hyperpin frontend. Update nov 27,2010
maddags:
Well a small update, as work has been busy.
Recieved my RGB pushbuttons, Leaf switches and the LED-Whiz from GGG the other day.
Installed 5 RGB pushbuttons and the LED-Whiz and cleaned up some of the wiring.
Also recieved my concators from europe this week, So need to mount and wire them up.
Placed an order for the CREE led's and then I should be done wirring.:beer:
Next steps are
- Install concators
- Make bezel for both monitors
- Install LED's on the backbox
- Mount side rails
- install playfield glass
- install speaker grill covers
- make instruction cards
- etc
I have one question regarding the LED-Whiz from GGG.
Is it possible to supply two different voltages to it from to different sources, ( 5v from a seperate PSU power supply and one from a dedicated 12V supply. How would you ground them?
Here are some picts
maddags:
couple more
chris77:
nice progress so far! :cheers:
you can drive your ledwiz (v2, small chips) with up to 4 different voltages (bank 1-4).
maddags:
Right, but I'm using two different power supply's. Would i just hook each ground from the power supply's to the LED-wiz ground terminal?
chris77:
yes, I think it's no problem.
