Main > Project Announcements
Leather covered Cab
shateredsoul:
well.. imo the arcade is looking great but the marquee throws it off a bit. Arcades are usually laminated.. sometimes you can see the wood, but you don't see marquee with a laminate or wood background. If you want to keep leather in the background.. Maybe if it was one solid color? Reminds me of a circus tent.
If you're going with leather for sure might as well use actual leather and burn the name of the arcade into it ;)
Rick:
--- Quote from: shateredsoul on November 23, 2010, 01:58:48 pm ---If you're going with leather for sure might as well use actual leather and burn the name of the arcade into it ;)
That would definitely give it some brand recognition!
:laugh:
skinz:
I was gonna get the Marquee printed on DuraTrans Material so it is properly back lit. I wanted to make my own out of leather as suggested but I'm not sure how it would illuminate. Back to the drawing boards I :dunno guess
I guess I'll do some tests?!?!?
newmanfamilyvlogs:
branding the name into the marquee would be very cool.
what about scraping away the backside so its translucent then using colored lights?
emphatic:
Brand the marquee, then paint the logo with invisible UV color and put a UV light at the bottom? Or have LED "studs" spell out the logo?
