Main > Project Announcements
Leather covered Cab
Pages: << < (28/31) > >>
newmanfamilyvlogs:
in the context of the flyback, the 'brightness' is the screen pot. There will only be two on the flyback: focus and screen.
The lines may be green because you need to adjust the green drive on the neckboard of the monitor. It might be just a little out of balance and you wouldn't notice until a defect draws your attention to it.
Edit: after watching the video above, the green is definitely up too high. What should be black has a green tint to it.
You'll be interested in the greyscale adjustment at the bottom of this article:
http://wiki.arcadeotaku.com/w/Setup_Adjustments_For_CRT_Colour_Monitors
skinz:
Also measure the B+ voltage. If it's low it'll wave something like that.
With my wavy line problem how do I check this B+ voltage.
And Cotmm thanks for answering- OK so there are 6 pots on the neck - 2 of each color - of the 2 green which would be the drive?  I just don't want to mess it up and turn the wrong thing - The monitor scares me - I also think the neck is cracked and leaking (its grounding itself with a little screeching from time to time. - can that be replaced?
newmanfamilyvlogs:
--- Quote from: skinz on January 18, 2011, 08:23:00 am ---I also think the neck is cracked and leaking (its grounding itself with a little screeching from time to time. - can that be replaced?
If the neck was cracked the vacuum would be gone and it would not be working. The capkit will help the screeching probably. I bet you'll smell some ozone back there too.
skinz:
OK so my monitor looks EXACTLY like this guys - I have a WG 7194 just like this guy and I have the EXACT wavy line at the top of the screen.  His problem was never resolved properly.  I don't have a Chassis to replace mine with and was wondering if anyone else has seen this problem.
http://forum.arcadecontrols.com/index.php?topic=99163.0
Nephasth:
I had the same problem with one of my monitors, although not as bad.
After asking about it on KLOV, adjusting the Horizontal Hold pot straightened it right up.
Go to full version
