Main > Project Announcements
Leather covered Cab
Pages: << < (23/31) > >>
skinz:
OK so this is what happens if anyone can help.
newmanfamilyvlogs:
That bright line at the bottom the screen probably means you still need to adjust the vsize pot.
I would recommend also installing something like UltraVNC so you can operate the machine over the network remotely while its connected to the arcade monitor. The will also let you double check that it's outputting the resolution you expect. I get the feeling that isn't really 320x240 when it comes back up.
BobA:
Wow  :applaud: :applaud: your leather finish really pops.  Clearly a work of art.
miggitymac:
We tried all kinds of settings but what you see above is the best we could get it!   :banghead:  Its really the only thing holding us from finishing this project..Please help us.
newmanfamilyvlogs:
install UltraVNC or your VNC build of choice.
Connect to it while it's running on the arcade monitor, and try different resolutions. I really don't think it's coming back up in 320x240, and with the screen off the bottom like that you'd have a hard time getting to quickres.
It's possible you can't adjust the screen enough because of it needing a capkit. That's worth doing as well.
Go to full version
