Main > Everything Else
Delay SENDING emails in Outlook???
<< < (2/2)
RayB:
I'm pretty sure sending gets stamped with the system clock in outlook 2003. I recall once having my YEAR wrong and my friends pointed it out, because that email would always be at the top of their inbox due to the date.
I can test. Which version of outlook?
thatitalian:
Hehehe, I was discussing this the other day funnily enough.
I thought delaying it (as you said) works? My colleague did it and it showed the delayed time, not the actual send time.
Rick:
--- Quote from: thatitalian on October 19, 2010, 09:16:39 am ---I thought delaying it (as you said) works? My colleague did it and it showed the delayed time, not the actual send time.
I believe this to be true, however, your system has to be in Outlook at the time.  There's a different way to schedule the delivery time, but as said above, the time the E-Mail is sent is still visible, and this is because (technically) the E-Mail has been sent, but is being held by the E-Mail Server until the time requested to deliver.  The delayed send feature works by leaving the E-Mail in your Outbox until the time to send it.  I've done this before - once WITHOUT the system being on - and I did not receive the E-Mail until the system was on.  This means, the E-Mail was in my local Outbox - not in the E-Mail Server - and thus, would not be received until my system was on and in Outlook.  When I retried, I left my system on and Outlook loaded, and had the delayed email send me a notice at 1:00 a.m., which I received promptly at 1:00 a.m. on my synchronized BlackBerry.  The date and time showed exactly what I wanted.
Now - at the time I tested this, I believe I was still using Outlook 2003.  The above information might have changed.
Navigation
[0] Message Index
[*] Previous page
Go to full version
