Author Topic: Cutting Tball and button holes in Metal CP?  (Read 1226 times)
Crayola
  • Last login:October 10, 2012, 04:13:23 pm
« on: October 09, 2010, 10:55:13 pm »
So I need to add a few button holes and a 2 1/4" trackball
hole to a metal control panel. Any suggestions on how to do this?
Would a hole saw work? I havent had good luck with hole saws
and metal. They tend to wander until they bite in. Usually where I
dont want it to:(
Crayola
JustMichael
  • Mmmmm!! Cheesecake!!
Re: Cutting Tball and button holes in Metal CP?
« Reply #1 on: October 09, 2010, 11:06:16 pm »
Greenlee hole punches make nice holes.
« Last Edit: October 09, 2010, 11:14:09 pm by JustMichael »
Crayola
« Reply #2 on: October 09, 2010, 11:36:04 pm »
Got a good source for them? They seem kinda expensive.
Crayola
JustMichael
« Reply #3 on: October 10, 2010, 10:30:17 pm »
Crayola
Sorry no I don't.  Also I have no idea what size for the trackball. You could find out how much a local machine shop would charge to punch the holes for you.
bkenobi
« Reply #4 on: October 11, 2010, 11:36:42 am »
You can use a hole saw or step drill for the buttons, but the trackball will be more complicated.  Are you planning on having a bezel of some kind around it?  If so, you can probably cut it with a hack saw and file it down to the final dimensions.  If the edge will be exposed, I'd get a machine shop to do it for you.
eds1275
  • Last login:May 03, 2024, 12:05:34 pm
  • Rock and Roll!
« Reply #5 on: October 11, 2010, 12:33:35 pm »
drill a small pilot hole... use a metal cutting hole saw. I saw a 3" one at Canadian Tire the other day, though it doesn't say so on their website.
gShooter
  • Last login:March 10, 2016, 02:12:46 pm
« Reply #6 on: October 12, 2010, 12:01:04 pm »
Not a permanent solution, but any metal shop or motorcycle/auto custom shop in your area might have a wet metal cutting machine, or laser which would help you for a simple fix.  The prices are pretty low especially if you show up in person.  Certain Napa Auto parts stores can also do it (along with sand blasting) for very little $$$.
Buying your own hole saw, or set, sets you up for life though might be too much $$$ for 1 cut.
