Main > Everything Else
3D televisions
<< < (12/18) > >>
Vanguard:
I read a report that said 2-12% of the population are 3D-blind.   70% sounds a little far fetched.   If the technology had that high of a reject rate, I doubt it would be considered a viable consumer feature.
SavannahLion:
--- Quote from: Gray_Area on October 14, 2010, 02:30:28 am ---The fundamentals are truly ubiquitous wireless, peripherals becoming wearables, and cloud environment liberating devices from processing demands. (D/A converters have become pretty inexpensive. The above could likely be helped along if broadcast were [still] analog.)
That's not even close to describing the fundamentals.
Frigo:
--- Quote from: pinballjim on October 14, 2010, 10:36:00 am ---Man, a couple of you should really see if NASA is hiring.  They're always looking for uncreative engineers.
I dunno, can you list "conjecture" and "speculation" as applicable skills?  ;D
ChadTower:
--- Quote from: AtomSmasher on October 10, 2010, 02:26:39 am ---So the TV will work for only one person at a time and that person has to wear something clipped to them?  How is this better then the glasses?
Don't you sit with the remote in your hand or on your chair?
Mikezilla:
--- Quote from: Gray_Area on October 14, 2010, 02:30:28 am ---These are developing - just not so much here as in Asia, where the culture is far more mobile and flexibility-minded, and where the youth have much more  involvement and say in it.
When you mean "asia" I assume you mean Japan?
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
