Main > Project Announcements
The "I Just Took On 16 Countertops" Project!
Pages: << < (5/6) > >>
BadMouth:
There are two red buttons behind the pull-out coin box (assuming this is a tabletop model).
One will launch the service menu, the other will launch the calibration screen.
You can also press them both simultaneously while powering up for a "two button reset", but you shouldn't need to do that unless you are switching software.
HaRuMaN:
This is a tabletop model, yes.  Cool, so I'll look for those buttons, too.  I assume they are inside the case?  There is one red square button on the outside next to the AT power switch.
BadMouth:
--- Quote from: HarumaN on November 23, 2010, 09:47:22 am ---There is one red square button on the outside next to the AT power switch.
Mine doesn't have that one.  ???
It's an XL6000 that was upgraded to gold (then upgraded to platinum by me).
Not sure how many variations there are being that most were upgraded over the years.
Here are the pinouts on the I/O board for the service & calibration courtesy of Paladin:
Image is from Paladin's site here: http://home.comcast.net/~dark.paladin/megatouch/
Paladin:
Not sure about the 'Gold', but the XL games also have a volume control in the setup menu in addition to the physical lever.
BadMouth:
--- Quote from: HarumaN on November 23, 2010, 09:47:22 am ---I assume they are inside the case?
Remove the coin box and you will see them along with a counter (it's interesting to know how much money the machine made in it's lifetime).
They are meant to be accessed without having to open the back of the case.
Go to full version
