Main > Project Announcements
The "I Just Took On 16 Countertops" Project!
Pages: << < (4/6) > >>
HaRuMaN:
I'm gonna stop by Frys on the way home from work tomorrow and get an AT power supply, thanks for the heads up.  Looks like they have one for $25, w00t!  I'll replace that and see what happens.
Monitor does have neck glow.  I haven't tried hooking up another video source to it to test it.  It is just standard VGA, correct?
BadMouth:
--- Quote from: HarumaN on November 21, 2010, 03:53:16 pm ---It is just standard VGA, correct?
Yep,  standard stuff.
I've used a bunch of different monitors for testing & currently use LCD touchscreens on both my machines.
HaRuMaN:
Replaced the power supply, and BAM!  Works great, monitor is clear, and the touchscreen is perfectly calibrated.   :droid :droid :droid
No sound, though.  Not bad for $50 and hour of my time.
BadMouth:
Sweet!   There is a volume control pot on the I/O board.  It's a little metal lever attached to two vertically mounted pots.  IIRC, it's in the bottom corner near where the speaker plugs in.  There is also a volume adjustment in the service menu.
I wouldn't be surprised if the speaker is blown though.  Mine was all crackly and had to be replaced.
It's 8ohm, but I don't rember the size off the top of my head.  I have a spare and can post specs when I get home if you like.
HaRuMaN:
Cool, thanks, I'll look for the pots and try that first.
How do you get into the service menu?  I've only messed around with JAMMA type games before this.
Go to full version
